T to the B
- Lenoir City, TN
I know...why would anyone put a crappy ol' low pinion 44 in their rig when they should just go D60/D70/Rockwell?!?!?!?!?!
Well, I did it because I found one in the junkyard for a 100 bucks that had new rotors, new brake pads and 2 good ball joints. If I feel the need for more "beef", i'll pursue the Jana54 modification(search on Pirate4x4) to put A D50 carrier/R&P with D60 shafts, and what-not outters.
Now that i've hopefully doused the fires and chants of "shoulda just bought a XXXXX", i've got some cell phone pix to show how it all turned out(so far). Hope to get it mounted up when it gets a bit warmer outside.
We were a lil' confused on how the LCA mounts were supposed to go on, but reading the directions about 5 more times cleared it up. They just didn't look right the way the directions said. However, when you looked at the Upper control arm mounts you can see that they're raised up. This allows you to get the LCA mounts flush with the axle tube....creating much needed clearance. The mounts on my D30 have taken a severe beating, even with 35's.
I apologize for the OE diff cover.
Funds are short and i'm gonna hafta run that for a bit.
Any questions/comments are welcome. I'll do my best to not sound like ignorant minded fool, but i'm not guaranteeing anything.
