CameronB
- Tacoma, WA
I overtorqued it on my 95... 2/3 of the threaded portion is stuck in the flange.
1) The bolt says FC 9.8 on the head, and I was using a 13mm socket on it.
Is this a metric bolt, with it's grade somewhere between 8.8 and 10.9 ?
I found that the 5/16 course thread nuts fit it at the hardware store, and
bought 4 bolts that look identical in grade 8. This is to replace all of
them. Haven't tried fitting them in yet.
Will they work? And, is grade 8 recommended in this application?
2) What's the best way to go about removing the stuck portion? There is
some bolt sticking through the back side of the flange.
Any other tips here would be great.
