Old January 19th, 2009, 19:10
wolf2600's Avatar
wolf2600 wolf2600 is offline
Chrome windshield trim & windshield replacement?
I've got a 92 Cherokee Laredo w/ the factory chrome trim surrounding the windshield. I called a place to come out to replace the cracked windshield, but apparantly when the guy came out (I wasn't the one who talked to him), he said he wasn't sure how to remove/replace the chrome trim, and wouldn't be able to do the job. He suggested I bring the XJ down to the windshield place's shop, and they'd try to do it there.
So..... my question: How do you remove/replace the chrome trim? Anything to note so as not to damage the trim while removing?
Thx.
Old January 19th, 2009, 19:44
BIGSLVRXJ BIGSLVRXJ is offline
Re: Chrome windshield trim & windshield replacement?
Something you may want to look into is having that chrome replaced with a later style rubber moulding/gasket. I have heard that it can be done with no mods, it would definitely be worth researching and talking to the glass guy about, unless you like the metal style trim.
Old January 19th, 2009, 20:20
confused confused is offline
Very strange. Most any windshield companies know how to remove the trim. The trim is held on by plastic clips that have a flexible part that you need to compress in order to release the trim. Harbor Freight has the tool to do this with. Cheap too.
Old January 20th, 2009, 05:35
veedubshafer's Avatar
veedubshafer veedubshafer is offline
Wow, that glass guy really knows his stuff doesn't he!
Old January 20th, 2009, 06:02
Steve_Moore's Avatar
Steve_Moore Steve_Moore is offline
I'd call around ....
Old January 20th, 2009, 09:10
ehall's Avatar
ehall ehall is offline
The trim just pops off. It's held on by some plastic clips that mount to posts in the channel around the glass. Basically stick a large blade under the outside edge, push the inside edge towards the glass while lifting the outside edge, and it will just pop loose. Once the trim is separated you can see the clips, which can be removed by pressing a tab in the center and sliding the clip towards the end with the hole.
If you want to upgrade to the later year gaskets, you'll need to Dremel the clip mounting posts down flush
my '91 beater rebuild
Old January 20th, 2009, 18:31
xj4fun's Avatar
xj4fun xj4fun is offline
Agreed. Any glass installer that doesn't know how to work with the trim I wouldn't trust to do the glass . I'd hope he's new on the job.
You don't need the trim or the related plastic clips if you have the installer use a 96+ gasket which doesn't use the trim.
I dumped my trim years ago, been much happier since
WTB: Windshield exterior trim BOB Arizona For Sale/Wanted 0 February 27th, 2007 18:41
Help! Get chrome windshield trim off? mhead OEM Tech Discussion 3 November 17th, 2006 15:41
Windshield trim SCW OEM Tech Discussion 1 February 28th, 2006 10:45
metal windshield trim 87manche OEM Tech Discussion 4 November 10th, 2005 11:04
Windshield Trim REDDOGG.XJ OEM Tech Discussion 4 January 1st, 2004 15:09
