Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
  #16
Old November 9th, 2009, 11:42
srmitchell srmitchell is offline
Re: Just Another XJ on tons, coilovers, 42's, etc. Build
This build is epic. Good job. I can't even finish frame stiffeners. haha.
You got the h1n1? That sucks.
Old November 9th, 2009, 12:11
.40CalPatriot's Avatar
.40CalPatriot .40CalPatriot is offline
Damn man that is coming along very well. You have some awesome fab skills. Good luck!
Old November 9th, 2009, 15:56
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Originally Posted by freerider15 View Post
More finished product...
Had so much fun playing with the dimple dies you just couldn't stop, eh?
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old November 9th, 2009, 18:28
freerider15's Avatar
freerider15 freerider15 is online now
Originally Posted by YELLAHEEP View Post
Justin,
As I've said before...... your fab work is simply beautiful. Sickness in steel brutha.
Question about the rear 4-link mounts on the axle in this pic:
I'm looking at this and seeing that the lower mounts have pivot points (at the joints) that's above the centerline of the axle tube/shaft.
I've not seen lower arm mounts attached to an axle that high before......
Any concern that the axle won't rotate sending the pinion upwards and possibly causing the lower arms to bind up against the upper arms - particularly when torque is applied - on an uphill climb - or similar?
Thanks Troy
As far as the links, no worry what so ever. There are quite a few build over on Pirate including Ashman that have used it and its worked great.
Originally Posted by Starboard M View Post
How is that any different than someone linking a portal axle?
I think its a dang good idea. Ive seen it done before, and have not seen any issues with the design assuming the mounts are strong.
You should ask Vetteboy about his raised links=stress goes to infinity thoughts!
Haha I ain't even about to ask him about that
Thanks for the compliments...yeah got the H1N1, about 70% better now so I should be fine mid this week.
Yeah I'm a dimple die whore, what can I say, and there will be many more in this build ...
Old November 9th, 2009, 22:21
Kiefer316's Avatar
Kiefer316 Kiefer316 is offline
Awesome build so far. Great looking welds also can't wait to see this in person
Old November 10th, 2009, 06:23
Jump This's Avatar
Jump This Jump This is offline
Just another minion!
Did you run the numbers on your upper link mounts for each location?
I have just about the same multi hole set up and the changes on the upper frame mount are HUGE!
You run from an instant center of 120 to somethink like 240 I'd bet.
And who the hell trusses a 14bolt? You will need a fork lift to move that bastard!
Old November 10th, 2009, 08:20
What ya think I didn't run the numbers after all that work?
Yeah I ran teh numbers and it varies me between ~60%, ~85%,and ~110% AS.
I'll get back to ya on my instant centers
Old November 10th, 2009, 08:35
Kittrell's Avatar
Kittrell Kittrell is offline
I don't know, Justin is pretty beefy. He can probably deadlift that.
Old November 10th, 2009, 09:01
Thing is, i've added maybe a total of 20-25 lbs to the whole axle... Hell my rear axle is quiiite a bit lighter than my front.
Old November 10th, 2009, 10:08
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I have seen one man carry a 14 bolt axle before. We had to lift it for him, but he carried it 20-30 feet with a towstrap around his neck and one in each hand.
(Ross (foxwar71) at the all-you-can-carry junkyard event a few weeks ago)
freerider15 - great build. As usual it makes me wish I had the fab skills, time, and money to put into a project like this.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old November 10th, 2009, 15:46
fyrfytr1717 fyrfytr1717 is offline
Wow, awesome work! I really gotta learn how to weld one of these days. As you're demonstrating, the possibilities are nearly endless...
Can't believe your landlord had an issue with you doing that in your garage. You also mentioned it's back in your garage now, new place?
Old November 11th, 2009, 07:24
foxwar71 foxwar71 is offline
that was some fun stuff, i diffenently coulda keep carrying it all the way to my truck if i had shortened the straps a little bit more. getting it off the ground was the hard part.
Justin, the progress on the jeep is looking sweet!!! i remember seeing that thing just on 35's with a D30 still, oh how times have changed. gunna do any truss work on the 60?
Old November 11th, 2009, 15:32
Jump This's Avatar
I'd be dead if I tried anything like that!
Damn....my back hurts just thinkin' about it!
Old November 11th, 2009, 18:31
in4aride in4aride is offline
Glad the build thread is going. After that teaser pic you sent I've been dying to see more. Props on the fab work. Jeeps gonna look a bit different from how it used to look in highschool lol
Old November 11th, 2009, 22:04
Yeah its in MY garage now, so I don't have to drive 10 minutes everytime I wanted to work on it. As well, I'll be able to work on it much earlier and later in the day. Yeah my old landlord or shall I say Realty company I could go on and on about the situation was so screwed up...guess thats one of the benefits of being a college student
Yeah its changed a BIT...but do I happen to know ya?
Thanks, sooooo looking forward to getting it done. I haven't been wheeling in over a YEAR due to the rig being out. By the time its done it'll be going on 2!
Rate This Thread:
full width and 42's 1999mj Jeep Picture Showcase 11 September 22nd, 2008 14:18
3.42's in a D44???? kjpeter OEM Tech Discussion 3 March 18th, 2007 08:51
just when you think you have it all, xj on 42's steve stiller For Sale: Private Party Only. XJ ITEMS ONLY 0 December 9th, 2004 20:43
