REALLY need to get rid of some parts, folks, cheap.
-- D35C rear from 86 XJ, 4.11 gears, open, non-C-clip shafts. The axle is complete with all factory mounts, brakes, lines (even e-brake), etc. I popped it open and the r&p look fine, no unusual wear. $50. Cheap way to slightly deeper gears and slightly more dependable (no C-clips) rear axle.
-- Semi-float 14-bolt housing. Empty housing with cover and bearing caps. Set up with spring pads and shock mounts for XJ running ~8 inches of lift. $50.
-- TF904 auto tranny from behind a 2.8 in 86 XJ. Ran when pulled. Pan was totally clean. Complete with tc, flexplate, shifter, whatever you need. $300.
-- 2.8 V6, block is toast, but all accessories are still there. $50 and I'll load it on your truck.
Thanks for looking. You can contact me directly at [email protected]
dion
dion
