Old May 31st, 2004, 11:21
boise49ers's Avatar
boise49ers boise49ers is offline
Turn signal switch
The switch in the column of my 88 XJ isn't working. I know this is where the problem is because I have hazard lights, and the BU lights work that are on the same circuit. The signals work every once in awhile for a couple blinks if you move the tilt steering in another spot. I have tried to replace one of these in an older car I had and it ended up way to much for my little brain. Has any one replaced this and also does any one know around how much to get it replaced. It has the wipers/wash tied into the same handle that comes out of the column.
Thanks !
Old May 31st, 2004, 11:30
tobzz tobzz is offline
Re: Turn signal switch
easy fix just get your self a stearing wheel puller and the tool fer removeing the lock plate, You can get the lock plate off withount the tool but its not fun.
Old June 1st, 2004, 08:33
Hawaiian Style's Avatar
Hawaiian Style Hawaiian Style is offline
I just got done replacing that thing about 2 weeks ago. It's called the "multi-function switch". It's not too bad a job and you can grab a new switch at pretty much any autoparts place. If you've got cruise it, mine ran about 48 bucks but I didn't have time to shop around at all. Sounds like the wires in got bent one too many times in yours...
Old June 1st, 2004, 10:04
Cherokee91Red's Avatar
Cherokee91Red Cherokee91Red is offline
I had that same problem, got hazards but turn signal wasn't blinking. Actually it was just a short in the wire. I removed the assembly and kinda straightened up all the wires and when i put it back in it worked. might be all the problem you got.
Old June 17th, 2004, 20:56
dandecicco's Avatar
dandecicco dandecicco is offline
OK hows this for you (just got the XJ and maybe you guys can help me from spending a lot of time searching). Right signal blinks, left stays on. fuse good. relay clicks, bulbs good. thoughts?
Old June 17th, 2004, 22:52
boise49ers's Avatar
Yep I know exactly what it is. The housing the bulb twists into go bad and need replaced. It has happened on both front signals of mine. Just buy an after market one that will snap into your turn signal lense. Then wire it up to your old wiring. Took me for ever to figure it out though.
Old June 17th, 2004, 23:07
dandecicco's Avatar
Thansk! This new fangled XJ is gonna casue me some issues and just after I got my CJ figured out. Cool! More fun
Old June 18th, 2004, 12:34
boise49ers's Avatar
Go to my website and see what I'm dealing with right now. I have a picture of what I just did. I have lockers waiting to install , but I have to get this fixed first. They are a chore , but I love it.
See yuh !
http://myweb.cableone.net/cherokeexj/
Old June 18th, 2004, 12:35
boise49ers's Avatar
See yuh !
Turn Signal Repeaters tacottle Modified Tech Discussion 0 March 10th, 2004 13:09
Strange turn signal 8700XJS OEM Tech Discussion 3 February 22nd, 2004 16:39
Turn Signal Problem brandonsxj OEM Tech Discussion 9 December 12th, 2003 05:39
Turn signal Hawaiian Style OEM Tech Discussion 2 July 30th, 2003 09:01
Turn signal / parking light weirdness brtb OEM Tech Discussion 4 June 20th, 2003 21:45
