WTB: 89 MJ Fuse box
Lowrange2
Abbeville, SC
A friend of mine has a 1989 MJ 4.0, 2wd, manual transmission.
The fuse box under the dash is cooked. They need a fuse box/dash harness.
I'm not exactly sure what will interchange. Maybe that era XJ fuse box would work? Idk.
I'm assuming that the entire dash harness is part of the fuse box.
Anyhow, if someone has something that will work please let me know.
Thanks, Andy
It is all one piece. You can use an xj harness and just remove what isn't needed for the rear. I've done it before and it was pretty easy if you have a couple wire diagrams to reference off of.
