bigalpha
Moderator
- Tucson, AZ
I know that Hi-Lifts are popular, and considered dangerous (I know, I know, let's not have that discussion again). What other jacks do you carry around in your rig?
OEM. hopefully I'll test it to make sure it is tall enough to change a tire before I have a flat.
I have the oem bottle jack works with my 34's. I also carry around a scissor jack, its usefull in certain situations. Both fit under the rear seat along with other stuff.
I have an old OEM Ford jack, I suppose it's a screw type. It has ~6"x8" base and extends to nearly three times it's retracted hieght. It has an adjustable threaded pad on top as well as a hook on the side for the bumper.
EDIT: HiLift is in the rig most of the time as well.
What are the pros and cons to scissor and bottle jacks?
...but haven't tested the jack to see if it'd even get the tires off the ground.
