Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old December 11th, 2008, 06:05
Robahr24 Robahr24 is offline
Step by step write up strokers
Planning on first stroker, pretty much know what I need to do but if I can get some step by step write up's to help me out, would make it a lot easier on me. Can somebody help me out with some links for this.
Old December 11th, 2008, 06:39
wolfpackjeeper's Avatar
wolfpackjeeper wolfpackjeeper is offline
Re: Step by step write up strokers
I am honestly not sure that I have seen a "step by step" write up. Most of them go by the assumption that you already know how to do a rebuild. Essentially that is all you are doing. You can look in a Chilton's or FSM and follow those steps for a major overhaul. The only differences will be when you substitute the 4.2l stuff for the 4.0l stuff.
Old December 11th, 2008, 09:55
seanyb505's Avatar
seanyb505 seanyb505 is offline
Wow is it your lucky day. At least 10 different stroker builds, many with pics.
http://www.jeepstrokers.com/forum/vi...a8eb4005 93f4
Old December 11th, 2008, 10:12
sweet, I knew someone would post up a link
Old December 11th, 2008, 11:42
Awesome, it will help me out a lot, thanks.
Old December 11th, 2008, 11:48
alex22's Avatar
alex22 alex22 is offline
Here are two good more good write ups.
http://www.jeep4.0performance.4mg.com/stroker.html
The author of this one goes by the name of "DrDino" on this forum.
http://www.angelfire.com/my/fan/stroker.html
~Alex
Rate This Thread:
Motor Mount Replacement - Step by Step kd5dwy OEM Tech Discussion 15 February 9th, 2007 10:22
Budget Long Arm step by step build COMING SOON! barillms Modified Tech Discussion 12 January 31st, 2007 21:08
QUICK STEP BY STEP ON FUEL PUMP REPLACEMENT afjeep2082 OEM Tech Discussion 8 July 10th, 2006 16:43
Need step by step for replacing radiator. Dexter OEM Tech Discussion 11 December 7th, 2003 07:33
First Step TriZZle904 Jeep Street and Performance 4 August 18th, 2003 07:35
