Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > NAC Fest 2006
NAC Fest 2006 June 8-10, 2006: Paragon Adventure Park, Hazelton, PA
Old April 23rd, 2006, 19:15
Menzenski's Avatar
Menzenski Menzenski is offline
Formerly Mambeu
What's your pre-NAC-fest to-do-list?
I know that there's a similar thread in the NAC forum, but this NAC-fest forum is so dead that I thought we could use one here too. So, what do you still need to get done before NAC-fest?
My list:
- new clutch
- new valve cover gasket, oil pressure sending unit, possibly other oil leaks
- remove rear swaybar
- homebrew discos for front swaybar
- mount fire extinguisher and first aid kit
- trim rear fenders and quarter panels
- mount rear bumper
- new lug nuts; I think my shop used an impact gun to put them on
- bedliner the interior
- build storage box
- if all that gets done and there's a week of nice weather, paint the XJ
I will be rolling on 31s, 3.07s, and a D35, with no armor, and no regard for sheetmetal. As long as I can drive it home...
  #2
Old April 24th, 2006, 06:45
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: What's your pre-NAC-fest to-do-list?
There's a couple threads on this in the NAC forum, but what the heck - let's breathe a little life into here...
I've done the following:
Speedo recalibration
New motor mounts installed (MORE Torsion Rubber)
Fix missing steering stop
The last two were done by a shop - the first because I'm not up to that level yet, and the 2nd because it was convenient to let them do so at the same time.
Still need to:
- Order/install rocker armor
- Replace catalytic converter (heat shields being rusted away kinda sucks on the trail)
- Rewire driving lights
- Retune CB antenna
- Switch and NAC stickers from "scotch tape" mounting to permanent mounting
Rob
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
  #3
Old April 26th, 2006, 12:37
juicexj24 juicexj24 is offline
Install ARB in rear 44, fill up Powertank, and change the upper and lower rad hoses, and rebuild the t-case Np242.
ARB and t-case is getting done this weekend by a shop.
Juice
  #4
Old April 26th, 2006, 23:04
mack's Avatar
mack mack is offline
make jeep drive...
  #5
Old April 26th, 2006, 23:07
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
plan A- win lotto and wheel my XJ at NAC-FESt
Plan B-get job save $$$$ pay somebody gas money and ride biotch the hole weekend
  #6
Old April 27th, 2006, 06:56
lobsterdmb's Avatar
lobsterdmb lobsterdmb is offline
Just a Lobster Minion
What happenned to "I will wheel my XJ at NACfest this year, I swear" ?
Johnny
Retired President
Support , become a member!
  #7
Old May 19th, 2006, 12:00
gabe4 gabe4 is offline
Get spare front axle shafts
  #8
Old May 19th, 2006, 12:37
MrShaft696's Avatar
MrShaft696 MrShaft696 is offline
get a first aid kit
  #9
Old May 20th, 2006, 13:44
nhrocker's Avatar
nhrocker nhrocker is offline
Jackstand wheeler
The biggest thing...get my new axles in. They were supposed to ship over a week ago, but it's just my luck that parts were backordered. If I have time after I get them I need to fab up some rocker protection.
  #10
Old May 22nd, 2006, 05:43
pick up a set of spare complete axle shafts so now if I have a brake I can just swap out the whole thing.
  #11
Old May 22nd, 2006, 10:25
NAXJA Member #920
Well, I got my rocker armor on this weekend, and am having the catalytic converter replaced the end of the week (took one look at 215K worth of heat and rust and said "NFW"). The list's getting shorter, and it's just the little things left to do that can, if necessary, be left until a later date.
While I'm thinking of it, here's a tip for you folks marking where to drill for rocker armor and the like: white-out works a heckuva lot better than a pencil - made my life a lot easier.
Rob
1984 Dodge Omni
  #12
Old May 22nd, 2006, 10:37
Menzenski's Avatar
Formerly Mambeu
All I really still need to do is finish Herculining the interior and mount my fire extinguisher, first aid kit, and two remaining tow hooks. Almost there...
  #13
Old May 31st, 2006, 19:19
Menzenski's Avatar
Formerly Mambeu
Originally Posted by Mambeu
My list:
- new clutch done
- new valve cover gasket, oil pressure sending unit, possibly other oil leaks not leaking any more
- remove rear swaybar done
- homebrew discos for front swaybar ditching the front swaybar for NAC-fest
- mount fire extinguisher and first aid kit done
- trim rear fenders and quarter panels done
- mount rear bumper done
- new lug nuts weren't needed
- bedliner the interior done
- build storage box not enough $/time
- if all that gets done and there's a week of nice weather, paint the XJ not gonna happen
All I need to do now is mount two more tow hooks, one front and one rear. Seven more days!
  #14
Old May 31st, 2006, 22:02
whatevah's Avatar
whatevah whatevah is offline
It's Yellah!
-remove rear sway bar
-finish wiring the 400W of lights in my signature.
  #15
Old June 1st, 2006, 10:10
NAXJA Member #920
Can't believe we're at T-1 week and counting. Where the heck did the last two months go?
Cat. Conv. is on. Now I don't have to worry about heat intrusion due to lack of heat shields.
All I have left are rewiring the driving lights, rerouting the CB antenna cable and trailer harness through factory town harness spot instead of out around the tail lights, and (most importantly) getting my /NAC decals and previous NACFest dash plaques mounted.
Let the last-minute wrench fest commence!
1984 Dodge Omni
Rate This Thread:
NAC-Fest '05 STROKER Non-Tech / Off Topic 1 June 13th, 2005 17:45
Almost done for NAC Fest juicexj24 North Atlantic Chapter 4 May 23rd, 2005 23:24
Nac-fest ROCKREADYXJ North Atlantic Chapter 117 January 17th, 2005 08:13
