Old November 6th, 2013, 19:38
kshbaja kshbaja is offline
Drum Brake Question - Parking Brake Cable Removal From Parking Brake Lever?
I am replacing the rear drums and shoes of my 2000 XJ for the first time. I have one side disassembled and am getting ready to put this puzzle back together. When I disassembled I noticed the parking brake cable is fairly well attached to the parking brake lever (lever inside the drum assembly, not inside the vehicle). Is it necessary to remove the lever from the cable? I tried to separate the lever from the cable but it seems to be on there pretty tight so I stopped to avoid breaking something.
Old November 7th, 2013, 06:50
winterbeater's Avatar
winterbeater winterbeater is offline
Re: Drum Brake Question - Parking Brake Cable Removal From Parking Brake Lever?
I would disconnect it so that I could clean and lube all the moving parts of the brakes. It should not be a problem.
Old November 7th, 2013, 09:29
Jeff in VA's Avatar
Jeff in VA Jeff in VA is offline
<---respect
little trick a buddy taught me....use a pair of needle-nose vise grips. Get the tips under the spring and push it back, then lock them on the cable. Then you can slip the barrel-end out of the notch in the lever.
I hate drum brakes....
Jeff
Old November 7th, 2013, 19:35
JeepNovice JeepNovice is offline
U can still clean it up with it there. Even w needle pliers is pita to put back in.
Old November 7th, 2013, 20:59
JWheeler JWheeler is offline
Two pairs of dikes make easy work of it but you can get everything cleaned up without removing it.
WTB Parking Brake Lever Assembly for 97 XJ MrSimon NAC Classifieds 4 November 22nd, 2009 07:32
1997+ E-brake/Parking Brake Lever needed ASAP!!! selarep Wanted: Private Party Only 0 May 18th, 2009 07:49
Yet, another parking brake cable question Oatmeal Modified Tech Discussion 1 May 28th, 2006 13:55
Parking brake lever operating rod SPSERG OEM Tech Discussion 6 December 28th, 2004 22:59
Parking Brake Cable jeepguy97 Modified Tech Discussion 10 December 9th, 2004 13:12
