Old April 21st, 2005, 18:27
89jeepxjw's Avatar
89jeepxjw 89jeepxjw is offline
Need ideas on how to fix
Ok to start off my xj has a 4 inch lift on it. After we buttoned up the frotn end the track bar would not line up with the stock hole,this being my daily driver i needed a quick fix and have read abotu guys drilling a new whole for it. I went ahead and drilled it but had terrible DW. I got out and looked while a friend turned the wheel back and fourth and the middle section on the track bar bracket between the two wholes had broken off so the track bar moves from the stock whole to the drilled on. So now im thinking i can weld a piece of steel to cover up the whole i drilled but dont really know of any other ideas. Help?
Old April 21st, 2005, 18:53
joecool's Avatar
joecool joecool is offline
Re: Need ideas on how to fix
I dont have any personal experience with this type of problem, but welding in a new piece of metal seems like the best solution to me. Then I would buy an adjustable trackbar.
SE CHapter Decal and Tshirt ideas... Kudzu South East Chapter 4 September 27th, 2004 06:40
A new TPS didn't fix the problem... any ideas? 90Pioneer OEM Tech Discussion 7 August 22nd, 2004 15:25
Console fix ideas Ralph OEM Tech Discussion 6 July 19th, 2004 12:53
need 2001 Wrangler F bumper ideas michael-esq Tow Rigs and Trailers 2 July 25th, 2003 13:11
DIY Oil pan skid...'show me' some ideas... Willis Modified Tech Discussion 5 July 25th, 2003 05:29
