XtremeJ
- East Otis, MA
I've got a 1990 xj with an auto and 3:55 gears. Anybody run 35s with a similar setup? Thanks.
XtremeJ said:I've got a 1990 xj with an auto and 3:55 gears. Anybody run 35s with a similar setup? Thanks.
azxjman said:I run 35s with 3.55s and yeah it does suck on the highway. And I get worse gas mileage than anyone I know. But it does just as good as anyone with lower gears does on the trail. So for everone who says it will be crappy on the trail I say BLAH BLAH BLAH!! Dont talk about what you havent seen. Also it is an auto and I have a gigantic tranny cooler.
azxjman said:Ok to start of with the cause of 90% of all transmission failures are caused by overheating so as long as you keep it cool and you dont go easy on the gas it should be fine. Now to start of the replys
offroadman83- Why dont you explain how because I run high gears that it would cause a reckless amount of body damage .
Goatman- why dont you explain why It wont work on the trail all you have to do is push the pedal further to the floor to achive the same thing that anyone with lower gears is going to get.
XJZ-way to jump on the band wagon xjz all you can respond with is that. It really shows how intellgent you are when you can only respond with calling me stupid but not a reason why. I bet you really know how those lower gears help you get over those speed bumps in front of wal-mart.
Thank you woody for responding without an insult like xjz the brillant over there you actually are just sharing you exp. and that is what a response should be.
XJZ said:Future trends:
Suspensions with very little flex.
Smaller and smaller tires.
Light duty driveline components.
