Old January 3rd, 2005, 12:44
pancake's Avatar
pancake pancake is offline
1998 XJ U-Joint Part #'s - Help!
I went to Napa and they mentioned two different part #'s for the joints. They gave one number (forgot - sorry) for the double cardan joint on the front driveshaft and 5-153X for (x1) front driveshaft and (x2) rear driveshaft. Someone else on Naxja mentioned I just need (x5) of the 5-153X joints. I guess the only difference is that the two for the double cardan joint have the grease fitting on one of the end caps instead of the fitting on the spider itself. Those two different joints are $25 each instead of $12 each!!!
Can someone help clarify? Also, I should replace the "Ball Centering Kit" while I'm in there correct? Is this a fairly easy job? Thanks!!!!
Happy New Year!!!!!!!!!!!!
Old January 3rd, 2005, 12:45
pancake's Avatar
Re: 1998 XJ U-Joint Part #'s - Help!
btw - 4.0 / AW4 / D35 / D30 / NP242 / ABS
Old January 6th, 2005, 18:54
pancake's Avatar
Anyone?
Old January 6th, 2005, 18:57
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
I don't remember the part numbers but when I went to Kragen, they had couple different ones as well. They all were same size and the only difference was greasing/non greasing as well as where the grease fitting was. Of course I ended up with the one where the zerk on the grease fitting interfered with something and I had to go and swap them out. So you might want to look at your driveshaft as well as the ujoints and you should be able to see which one will work for you.
You also might want to search for it around on the forums as I think it was discussed not too long ago and someone did mention part numbers.
Old January 6th, 2005, 22:27
bj-666's Avatar
bj-666 bj-666 is offline
what are you trying to do replace all joints in both shafts. or replace a broken one or what need a little more info. if it aint broke dont' fix it.
Old January 6th, 2005, 22:36
JEEPZZ's Avatar
JEEPZZ JEEPZZ is offline
Stock joints are Spicer 1310's, whatever that converts over to in Napa-land.
Old January 7th, 2005, 13:49
pancake's Avatar
The original joints have 146k miles. I hear clunks and such. Time to throw some new joints in there. Should I have the driveshafts balanced also? Is it needed? I think the shafts have been taken apart before and I do get some noise / vibes...but not much.
Thanks!!
Old January 7th, 2005, 16:13
Digger87xj's Avatar
Digger87xj Digger87xj is offline
If you have never rebuilt a cardigan/cv joint in a driveshaft, or seen someone do it, it isnt an easy job, with that many miles the cardigan halves will probably need replacement too.
With 146k miles, I'd suggest pulling the shaft and send it to a driveline shop. they will rebuild it and re balance it AND then you will have some kind of warrentee. You will save yourself many many headaches and lotsa time.
Old January 7th, 2005, 17:41
pancake's Avatar
Oh really? I've done u-joints before but never double cardan. Hmm, are driveline shops expensive? I'm in WA now (Bothell). Anyone know of a good shop?
Old January 7th, 2005, 20:29
98_jeep_XJ's Avatar
98_jeep_XJ 98_jeep_XJ is offline
I replaced all u joints including the double in my 98 with tom woods u joints. It was not hard but was tedious and time consuming. There is a little hum at around 75 mph. I am going to take it to a shop and have them check it out. There is a 2000 shop manual some where on line maybe one of these links, had everything I needed to show me how to do it.
http://www.4x4wire.com/jeep/tech/
http://www.pirate4x4.com/tech/billav...DFs/index.html
Old January 7th, 2005, 22:37
IdeaMan's Avatar
IdeaMan IdeaMan is offline
I get a little clunk when I put it into drive. My '97 has 150k miles on it. Is that more than likely U-joints?
Old January 8th, 2005, 18:20
98_jeep_XJ's Avatar
Yep, pretty much related to u joints that are worn out.
Old January 8th, 2005, 18:38
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
http://www.federal-mogul.com/cda/con...9_8460,00.html
I used the super strength u-joints for the double Cardan with the grease fitting on the cap and replaced the little ball assembly with a new one made by Spicer, it has a flush grease fitting, cost $35. I alighned all the grease fittings so that they can be greased without having to rotate the shaft.
Old January 10th, 2005, 12:53
pancake's Avatar
So should I worry much about having the driveshafts balanced? If I do have it done, they won't be balanced with the yokes attached so would I really benefit from it? Can I cause much damaged if they are not balanced well?
Thanks
Old January 10th, 2005, 12:55
Kejtar's Avatar
PostMaster General
Thanks
Well if it's not balanced you might be getting vibes from it when it's spinning.
Which part of your XJ is a guaranteed rock magnet? Kejtar Non-Tech / Off Topic 41 July 1st, 2006 12:47
1998 D30HP swap into a 2000 XJ Need Help PLEASE MoFo Modified Tech Discussion 29 July 15th, 2004 21:35
93 XJ 4.5 LIFT**PICS** Part Out Bentonedge For Sale: Private Party Only. XJ ITEMS ONLY 16 June 14th, 2004 23:04
1998 XJ, 35" MTR's 5 Speed, D44 Detroit...in MA TOZOVR For Sale: Private Party Only. XJ ITEMS ONLY 9 June 3rd, 2004 13:38
1998 XJ trans low/2nd gear & TC lock-up? chucknewell Modified Tech Discussion 8 April 16th, 2004 18:41
