Old October 19th, 2019, 17:13
Tonybeirut Tonybeirut is offline
Hood vents and rear hood lifting
Guys. I have good vents and 2" lift at the back of the hood but I still can't touch the hood it's burning my hands.
Coolant temp is normal engine temp is normal.
Anyone has encountered the same problem? I mean I can fry eggs on that hood even with the 2 mods I did.
Old October 20th, 2019, 01:34
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: Hood vents and rear hood lifting
The exhaust, engine and radiator produce a lot of heat and while hood vents may help some, at low speeds, the exiting air is still very hot, it's the nature of the engine bay.
As long as your engine and transmission are not overheating, I wouldn't worry about it.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 20th, 2019, 07:19
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Park In the shade.My hood gets hot even if the engine is,nt running
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old October 20th, 2019, 07:41
TRCM's Avatar
TRCM TRCM is offline
Probably not as much shade where he is as what you are used to.
Old October 20th, 2019, 15:16
lazyxj's Avatar
NAXJA Member #1310
You never know, Lebanon has mountains, with peaks up to 10,000' and ski resorts.
https://en.wikipedia.org/wiki/Skiing_in_Lebanon
Old October 20th, 2019, 16:33
TRCM's Avatar
hence the word probably..........
Old October 20th, 2019, 16:53
MickeyS MickeyS is offline
same here. that's the way it is! though the jeep never overheats in the summer I have to play hot potato with the hood. Look at the intake air temp... it can get close to 200F in the summer here!! It's just the way it is.
Old October 20th, 2019, 17:12
Where was that green smiley face...... Be sure to use butter when you fry that egg, otherwise they stick.
Wayne
Member#17
Old October 20th, 2019, 23:03
Black1990jeep Black1990jeep is offline
My 1990 has factory insulation on inside of the hood, my friends 2001 has no such insulation. does your hood have insulation on the inside? That may help keep it cooler.
Old October 24th, 2019, 09:35
Rockwood Rockwood is offline
Raising the rear of the hood decreases airflow at speed. Get rid of it unless you're only rock-crawling the thing.
Old October 24th, 2019, 12:11
Scrubber3 Scrubber3 is offline
Im not going to say you are right or wrong on this or even disagree with you. Im certainly not advocating using hood risers. Im just wondering what proof you have to make this statement. Good solid proof.
Old October 24th, 2019, 12:18
OP, if your XJ is black or a dark color and it's sunny out, there is nothing you can do. It's gonna be hot. Let's consider that everyone has a different level of heat they can endure and what might make you hurt when you touch it, might just be uncomfortable for some. I know my woman will take a shower hot enough to nearly scald me and my shower is way too cold for her. So maybe get us some actual temperatures so we can help better. Keep in mind that 195 degrees Fahrenheit is normal operating temperature for the 4.0L.
Hood vents versus hood cowl/scoop Tryfan OEM Tech Discussion 8 April 22nd, 2012 09:01
Hood Vents VS. Hood spacers? What are you running? Plays For Jeeps Jeep Street and Performance 96 November 7th, 2011 16:31
Lebaron hood vents and ZJ rear discs millhousenator MWC For Sale/Wanted Forum 17 November 22nd, 2009 00:36
Hood with holes for hood vents souske SoCal For Sale 0 November 14th, 2009 19:02
Hood for sale, white, w/hood vents tcm glx SoCal Chapter 2 September 6th, 2005 22:14
