Old October 2nd, 2019, 20:42
RCP Phx RCP Phx is offline
Custom plug wires
I am going to need a full custom set with straight, 45*s, and 90* spark plug boots on both ends. Any recommended suppliers? In case anybodies wondering, 2000 going to a Viper coil!
Old October 2nd, 2019, 22:31
bajabronco bajabronco is offline
Re: Custom plug wires
Ron, what is the benefit of going to the Viper coil pack? Is it just to get rid of the coil rail? Is there a performance benefit?
Old October 3rd, 2019, 03:11
Ralph77 Ralph77 is offline
Any auto parts store should have what you need to make custom wires.
Where are you mounting the coil?
I am considering going with this:
https://www.ksuspensionfab.com/store...Coil_Mod_.html
I doubt there is much of a performance benefit but being more traditional I would not mind having wires instead of the coil bar.
So with this thinking something around a '03 3.3 liter Grand Caravan or the like stock wires would work.
Cause I am thinking of just buying the bracket and harness and will piece the rest together myself cause I can do cheaper.
Here are the wires for the at the Napa site. If you scroll down you will see the words Buyer's Guide. Tells you all the vehicles that these fit.
https://www.napaonline.com/en/p/BEL700112
So to double check this maybe scope them out at the boneyard.
Then if looks like it works buy new ones.
Old October 3rd, 2019, 07:58
The benefit is to be able to pull a "individual" plug(reading on finding "TDC").
I want "custom made" wires to eliminate the hassle of doing it my self with only one hand. There are no "applications" for this.
The coil will be mounted to the 2 center coil rail bolts.
Old October 3rd, 2019, 08:01
That was supposed to read (reading or finding TDC)
If this works out well I'll also p/u a Screamin Demon coil.
Old October 3rd, 2019, 09:16
Heavyopp Heavyopp is offline
Here's mine -- been running it since 2017 -- I choose to build a mount around the overflow bottle
I'm pretty sure the wires are from my 97 parts cherokee
Old October 3rd, 2019, 12:55
Heavyopp ..........???
Ralph77, thanks for the link. I didn't know anyone was making a longer harness. I contacted them and ordered (2) 12" harnesses (they said theirs is about 21" long).
https://naxja.org/forum/showthread.php?t=1148702
Old October 3rd, 2019, 13:09
So I was going over that thread cause I am pretty sure I never saw that one before. I purchased the WVE 1P2041.
https://www.rockauto.com/en/parts/wv...connector,2592
My goal, not knowing if it would work, was just to have a little more wire to be able to move the coil bar on my '00 a little more.
Did not work. Jeep was not starting misfiring and backfiring when did. I was all sorts of bad. But it connected no problem. Looking closer at the WVE it appeared that the spades in the male part might not have been long enough to get into the female connector on the wiring harness.
What did you mean when you said "but I will have to remove the "white" rib on the coil connector".
Old October 3rd, 2019, 13:12
Knew I forgot something. Wish I could edit here. You ordered 2 12" but theirs is 21". They are making one for you? I don't understand.
Old October 3rd, 2019, 13:50
The JK coil has a extra rib on the connector(see the thread/pics)
Yes, they will do custom lengths, I spoke with them about custom pinout's but.......
Old October 3rd, 2019, 13:57
Now I get it. I saw the rib you Dremeled off but failing to notice it was white threw me off. Thought you did something to the inside of the connector itself.
I talked to them to. Working at Napa and the local Mopar Dealership being a customer of the store I have an in. So I was thinking of getting a real Mopar coil for that set up and buying the wires from the store. They were nice enough to tell me what year, what I posted above would be good. Did say one wire might be a little to long though.
Old October 3rd, 2019, 13:58
Damn edit. LOL.
Still wondering, for sure, why I could not get that WVE part to work.
Old October 3rd, 2019, 17:13
I don't understand -- Aren't we talking about viper coils?
Old October 3rd, 2019, 19:59
Evan03 Evan03 is offline
Do it buy the foot
https://rover.ebay.com/rover/0/0/0?m...33 3326574388
Old October 3rd, 2019, 20:56
I was thinking you posted a pic?
Spark Plug Wires Tom R. OEM Tech Discussion 17 February 4th, 2007 11:31
4.0L plug wires jeepkid2000 For Sale: Private Party Only. XJ ITEMS ONLY 0 April 6th, 2005 22:22
oem plug wires jeepbme OEM Tech Discussion 9 March 4th, 2005 01:48
Plug wires tireroastin93XJ OEM Tech Discussion 3 December 30th, 2004 11:50
Spark Plug Wires? BIGSLVRXJ OEM Tech Discussion 2 July 9th, 2004 08:48
