This is the beginning of our entirely new DIY product line. The same high quality mounts and pieces we use on our own bumpers are now available for those wishing to build their own. Can save you a lot of time and aggravation! Everything is CNC laser cut for the utmost in quality and consistency. Our new tire carrier hinge is nearly ready to be released as well, puts the spindle mounts to shame! :worship:
Front Bumper mounts, incorporate a steering box support on the driver's side this setup has proven itself over the years on our own bumpers. 1/4" thick steel, 17" in total length.
$45 shipped to your door for the pair
Rear Crossmember Mounts, constructed from 3/16" plate they're a good start to a rear bumper using the factory mounting points. Our framerail mounts will be available shortly.
$23 shipped to your door for a pair.
D-ring Mounts, 3/4" thick steel with a 1" hole works perfectly with 3/4" shackles that have a 7/8" pin. (We will have those shortly as well). Long enough to extend through a bumper, same way as we do ours for the ultimate in strength!
$35 for a pair shipped to your door.
The "Harpoon" D-ring Mount, 3/4" thick steel it has a more flared look and still retains the strength of the pass through mounts, best of both worlds!
$40 for a pair shipped to your door.
Also our SuperRails outer tube, pre-bent and cut out of 1.75" round tubing with the supports $75 shipped for the pair! Pics coming soon. Call/PM/Email me for a package price for multiple pieces. Check back often as we're adding more pieces soon!
