- NJ, U.S.A.
Well, ended up not going high-clearance on the shock mount, just had the original straightened and welded back on (and a new stud put on it). Replacement for the dented shock arrived today, I'll put it on tomorrow.
Carpets are dry but haven't vacuumed or shampooed yet.
Went to open the passenger front door yesterday and couldn't get the door to unlock. Got the interior panel off this morning and found the lock solenoid frozen up. Pulled the linkage from between it and the lock, and the lock itself works fine, so new solenoid on order. Think it's been going for a while, the extra load from this one was probably what made the other locks not work right, but the dunk it got last weekend was likely the last straw.
Also have a theory on my CB issues, the "counterpoise" wires are probably too corroded to create a good ground plane anymore, so will have to run new ones. Fortunately not too bad a job, so will do that and see if it helps any. Certainly won't hurt...
