Rockclimber, good stuff, thanks for clarifying.
Moving on, here’s the story on those frame rail steel plugs that didn’t work want to thread as planned.
Sometimes when you’re pushing hard trying to get something done you make decisions that come back to haunt you. Sometimes shortcuts work out OK. Sometimes you think you can get away with more than you can. I’ve often told non-car people that wrenching on cars is about overcoming the unexpected difficulties that crop up. Whether it’s the rusted bolt you just broke, or the part that didn’t quite fit like expected, you can never productively finish projects unless you can find a way to overcome those challenges.
I knew I’d set myself up for some pain, drilling 12x holes through ~1/2 steel by hand. That’s not easy nor particularly fun no matter how you slice it. For drilling steel I like using about 1/8” bit. Bigger and it’s too slow. Smaller and it’s too easy to break bits pushing with enough force to get it to cut (and not just smoke the bit).
First four pilot holes drilled OK. I was using basic Harbor Freight Titanium Nitride Bits (their basic machinist set). Hole 5 gave me a bit of a challenge, had to break out the drill doctor. It was still kinda slow cutting so I reached for the small set of Dewalt split point bits I had and drilled all other 8 positions without too much difficulty.
Whew, hard part past I’m thinking… Now that I have pilot holes I should be in the clear. Jumped up to an "H" sized bit (Ti Nitride again) as I’m only planning to tap for M8 bolts and they don’t have to be huge. Again first four holes drill fine. 5th hole… Will not cut. Drill doctor again, make sure the bit is perfect, plenty of cutting fluid, varying pressures, varying speeds. Will not cut.
I’m not ready to give up so I head over to HF and buy their machinist cobalt set. Those weren’t out when I originally bought my other ones a decade ago. Yes, you can get stuff that’s more bad ass, but I’m pretty careful and I’ve had decent success using their stuff in the past. Cobalt set still runs $110 in drill bits, they're a little brittle but good in a pinch.
Take it back home and manage to drill all the holes. #5 on driver side is still the sticky spot but at least I prove the drill doctor works on cobalt bits too. Split point on that bit gets a bit shaved down in sharpening but I can live with that. Any time I’m reaching for a cobalt bit this big I’m going to have a pilot hole already.
OK, time to tap this thing.
I’m up again the bottom side of the rig, but I figure out I can use a square drive socket and wrench to apply torque with good force and still keep the tap stable and straight. Definitely going to use this trick again...
Again first four holes go OK. Takes some significant torque to cut but it’s working. I can feel it start to bind up so I’m reserving regularly to break my chips. I have Tap Magic cutting fluid dripping off this thing… Basically I’m doing everything right that I know of.
Hole 5:
Back out the tap and it's fubar'ed about as deep as I cut... Dammit. Couldn’t feel the difference between cutting threads and the plug ripping the teeth off my Craftsman tap… What the F was this metal? The stiffener itself cuts like butter by comparison.
So I take the bar stock I used into work and we break out the hardness testers.
Exterior of the bar measures 27 HRC. That’s not mild steel but it isn’t too ridiculous. Head machinest sends me home with a bad ass tap, supposedly rated to 45 HRC and some Castrol Moly Dee cutting fluid. We also talk about opening up the pilot holes a bit to make things easier.
I get home and drill all the hole out to a “J” without much difficulty. I start using the bad ass tap… chase the first four holes and get some decent crap cleaned out of there.
Hole #5, get it started… IT’S CUTTTING! I’m being as smooth as I can be… I just start to feel the chips loading, I hear the tiniest of cracking noises, so I go to reverse… and promptly break off the tap in the hole.
Well, I’m not fitting an EDM under my car to burn out a tap and/or cut threads. I’m doubting this is tappable at this point… and I owe my machinest a $30 tap. Screw it I’m done. Sometimes, you can overcome the difficulties, sometimes you have to know when to cut bait and run. I’ll just have to add fresh holes in a different position.
I wish this story had a happier ending, but for the moment it’s mostly a cautionary tale. I was just pushing too hard to keep things moving that a shortcut in material choice burned me bad. Live and learn.
I was frustrated enough that I couldn't stand tapping another hole and I moved on to other things...
-Joel
