View Single Post
  #3
Old April 9th, 2006, 21:25
Jared's Avatar
Jared Jared is offline
Re: Dana 44/Ford 9" out of 1979 Bronco?
Not true, at least some of axles from 1979 broncos have c-bushing mounts that are welded on. I thought that 77-79 F-150's and broncos are all welded on, but don't hold me to that. I have a set sitting in my back yard right now from a 1979 Bronco with welded mounts.
I'm planning on putting them in my TJ, which has an identical front suspension setup to an XJ. I will be keeping the radius arm setup, but lengthening them 6-12".
In my humble opinion, the wagonneer D44 swap is the easiest and the best fit. Low pinion axles really don't bother me.
Jared
