HP Dana 44 and Ford 9"
IslanderXJ
Axles out of a 1977 Ford F-150
Full width, around 65" wms-wms
Dana 44
-High Pinion
-5x5.5"
-Chevy Knuckles, machined, drilled and tapped for high steer arms.
-Warn Lockouts
-No Brakes, uses 76 chevy truck calipers and 77 Ford rotors, cheap easy to find.
Ford 9"
-31 Spline
-Big Bearing Third
-Drum Brakes
Both axles are torn down and have minor surface rust. Needs quick sandblast/scotchbrite followed by some paint and new bearings with seals.*
$1000 OBO
Sent from my SM-T810 using Tapatalk
Still in San Luis Obispo, but I have friends that go back and forth that could drop them off.
Right, I was thinking of IslanderOffroad, also from Catalina but moved to texas. :)
Carry on, sorry to interrupt. ;)
Will you sell the front axle alone?
can you post a pic of the housing, hubs, and knuckles?
Do you have the chevy small bearing spindles for the ford rotors?
Possibly, make me an offer.
I have both the Ford and Chevy spindles and hubs.
I can grab some pics when I get back home.
Yes, please pics. Is it geared? Locked? I'm not sure how complete it is to make an offer.
Chevy made a big bearing spondle but only the small bearing one works with 5 x 5.5 so i want to make sure you have the right one.
3.55s or 3.73s, no locker. Stock shafts
It would be small bearing then
