Timmay
- Marlton, NJ
I decided to fab a semi bolt on traction bar to cure my axle wrap in the rear.
I used 2x2x1/4" for the main crossmember and the bar itself. Poly bushings are from PolyPerformance and the adjustable sections are 1" B7 allthread and 1" square nuts ground down to fit in the 2x2.
Tube inserts ground down...
Welded in the tube with the old fluxcore...
Bushing kits welded to 1.25x.120 HREW and all of it welded to the allthread.
Axle mounts are CNC plasma cut from school.
Here's the crossmember all welded up.
http://i74.photobucket.com/albums/i273/Timmay822/Traction%20Bar/CIMG7955Medium.jpg[img]
[img]http://i74.photobucket.com/albums/i273/Timmay822/Traction%20Bar/CIMG8091Medium.jpg
It uses a shifty shackle to allow the bar to flex with the axle...
This is how the crossmember sits...
The bar all tacked together...
Everything...
Holesawed 1" holes in the framerail and sleeved with 1/2" home depot poop pipe.
Fully welded the bar and painted everything with hammered rustoleum.
Everything...
