MrShaft696
- Blue Bell, PA
To do
Install lift.
Buy tires
Rebuild rear brakes
Install rear bumper.
what did you get for a lift?, need any leafs i have a stock pile....
To do
Install lift.
Buy tires
Rebuild rear brakes
-install chromoly shafts in front. DONE
-install new 7075 tie rod and goferit flip insert. tie rod installed still need to install flipped knuckle
-weld in skids for lower control arms.
-mount all 4 shocks with new brackets so they are the proper lengths. Not gonna worry about them. Working just fine.
Might as well keep the tradition going of myself starting this thread :laugh:
- Swap out oil pan dipstick for locking one
- Spend some time tuning the motor (ideally I'd love to get on the dyno)
- Swap out iron heads for aluminum heads (pending my uncles time)
- Brace air bumps back to frame
- Fix leaky tires
- Get spare leaf springs
- Fix rear diff breather
To do:
-Replace accordianed downpipe with tj downpipe
-find muffler that actually muffles
-remember to air up tires
Trailer:
-replace ALL shackles/leaf bushings/equalizer bars
-find a spare
-replace/wire electric brakes...
Truck:
-FIRI till it blows up
Fixed and added for you.TO DO:
-Finish Adam's Jeep ASAP
-Make hoop for Sam's Jeep
-Pay NAC
-Power wash jeep again after rolling around in mud
-Check fluids, think I lost some PS and brake fluid on the flop
-Fix trailer PS fender, rear welds broke off
-Source and Install flip out tow mirrors on Jeep
DONE:
-Change oil and filters in the Jeep and in the Dodge
-buy and install fire extinguisher
-Finish Adam's jeep
-Make hoop for Sam's jeep
build a front driveshaft
get the ecu tuned - MAKE APPOINTMENT
make a crossover bar for the coilover towers- make ross do it.
build exhaust from the Y pipe back
breather hose stuff
mount front air bumps
mount front limit straps
Install fire extinguisher mounts.
Bolt in my shiny new rear shaft.
