The Stupidist Jeep on the Planet
such a tedious annoying taskkk im putting off installing my rears cuz i dont feel like stripping the undercoat..
norton rapid strip disc from home depot kicked some serious ass, i found it very easy
got the stiffners stitchwelded on, just gotta do the bazzilion plug welds now
this week will consist of removing whats left of the floors and installin floor subframe and/or installing rockers/boatsides
instead of finishing up the stiffners tonight i decided to start on the rockers/boat sides cut like 2"ish out of the bottom of the doors
maybee a inch, still got to cut a inch off the lower fender for tire clearence, 38's take up alot of room
Ok, that makes sense. I've got one side of mine done like that. I wanted to move them far enough forward to use as a base for my cage in the future but far enough back for tire clearance for the 37s that I can't afford. lol
not so much got done this weekend as i has a not so fun stomach virus, but the drivers rocker is in, still gotta make supprt pieces that conect them to the frame stiffners
what size box is that? idk if you said that or not
its 2x5x3/16 with 1x1x.125 to space it out, i kinda wished i went with 2x6 spaced out a inch to help with protecting the doors but i tink ill add a piece of dom to the sides for that
got a solid amount of work done today, started with a piece to the subframe of my floor
then made a plade for the sring hanger
then welded said plate in
after that i welded in 2 of the rocker support, got 1 left but ams outsa wire, ill get more tomorow after works
not a whole lot done today, weather was nice, mid 70's so i rolled the jeep outside
then removed the pass. doors and what was left of the rockers
gotta do some patch work before the new rockers go in
