muddeprived
- PA
Can we get a side shot?
To me it look like the lower bracket hangs sorta low.
I think it does. Looks similar to the drop brackets that I had on, maybe an inch higher.
Talk about ground clearance loss :shocked:
it's not that bad. If you are running 33's or 35's it shouldn't be a problem.
I didn't say it's a huge problem, I just don't get why it's so hard to mount them inline or above the frame rails.
I'm sure it will wheel just fine and you'll land/slide over the mounts. Just not a very good design if you ask me.
Also, if the lowest spot hangs ~3" below the rail, you basically just lost the ground clearance you gained on 35s from stock tires.
True. I guess it's based on what kind of wheeling ya do. I do mostly mud and forrest trails and very little rocks so the clearance wouldn't bother me but for someone who sees rocks alot will likely be turned off by the clearance loss. Trek's is by far the best long arm kit with a belly pan you can buy. You can even use it with a 3" lift unlike most LA kits out there. If I'm correct, the LA's on trek's mount inwards and not directly under the frame rail and this allows for gains in clearance and also clears the arms from hitting the frame rail during uptravel, which is why most kits state 4"+ for their LA's to work.
so besides the ground clearance issue is there any other negatives to this setup? everything seems pretty sturdy?
I haven't seen any bashing.
If you're on the road 99% of the time, this kit is fine and will improve ride most likely.
If you wheel on trails where there are ledges and rocks that WILL scrape your undercarriage, this kit has the potential to hang you up.
I'm not a fan of losing ground clearance in a critical area (breakover angle).
so from everything i have heard there really isnt much wrong with the Rough Country setup? i have heard a lot of bashing but i dont see how much of it would really make that much of a difference. to me it sounds like a nice stout upgrade for a mild to moderate wheeler
