Here's a list of the parts that may be removed/resold. Keep your eye out for them.
Suspension/Tires/Axles/drivetrain:
-RE 4.5" springs painted silver, 1.75" spacer
-35"x12.5” Goodyear MTRs (old style-siped) on D-hole black steelies
-Iron Rock Offroad OTK steering (black, super thick, really weird design – stands out)
-Claytons long arms/cross member
-D30 front Eaton e-locker 4.88 gears, chromo shafts. Red Riddler diff. Cover. Red brake calipers
-Ford 8.8 with 4.88 gears, LSD. Red Riddler diff. Cover. Red brake calipers (has chipped gears, axle makes noise)
-RE 1.25” grease-able shackle
-RE 3.5” lift full-leaf springs
-242 transfer case with a Hack-n-tap SYE using a stock front XJ shaft on the rear
-I6 4L engine approx 180k, new valve cover gasket, year old (t-stat, water pump, alternator, starter, TPS, O2 sensor)
-4 Bilstein 5125 shocks (10” travel front, 8” travel rear)
Armor:
-LED tail lights - THOR guards (quarter panel protection)
-4x2 rocker replacements
-Bent front winch bumper and homemade rear bumper (both bent on the passenger side)
-HDEngineering shackle relocation brackets and frame stiffeners
-Rustys 242 t-case skid
Parts:
-Custom routed magnaflow exhaust (stainless muffler)
-CSF 3-row aluminum radiator
-Aluminum overflow bottle
-Upgraded aftermarket grounds – multiple engine/battery/alternator ground cables
-Clarion DXZ385 deck
-4 Kicker KS650 5” speakers (pretty sure that's the right model/size)
-Tinted rear windows
-4 HF fog lights
-Hella H4 housing with Silverstar bulbs
-Aftermarket light wiring harness in yellow with 2 relays
-Leather two door seats, drivers side is ripped.
-Homemade rear tool box, designed to fit in the cargo space with a pull out drawer and lifting half top
Inside the vehicle:
-2 brand new wheel bearings
-1 used alternator (spare part)
-1 full set of Craftsman socket wrenches (on crappy/bent HF socket holders)
-3rd generation 8 gig nano ipod with “GO COUGS” engraved on the back
-Large HF adjustable wrench
-36mm socket
-ARB ORANGE strap, with two ripped yellow straps all in a Master Pull red bag
-Craftsman bench vice in red with a bent handle
-M-frame Oakley sunglasses with polarized blue iridium lenses – with a hard case
