ruggedjeep
- Sherman Oaks
:bawl:wow, crazy. That looks pricey!
I know a guy in phelan, but I don't think he does that type of stuff. I'll check with him.
This is not something he does. He suggested you call a temporary power company like the guys who put in power at jobsites. He however does not have any recommendations since his contracts specifically exclude temp power. Good luck.
Throw a winch line around that bad boy and stand it up.....:twak:
Is this pole only supplying the drop to your structure or does it also branch to others ? (can't tell by the pic)
Hopefully you have already gotten this worked out but:
Try ACO temporary power they are in the 818 but do work everwhere. A friend of mine has used them before for the same type of work at his house. Be warned it wasn't cheap. He recommeded buying a pole and and renting a post hole digger and sinking the pole yourself (jeeps with winches) and then just have an electrician move the wires over.
You can also try Fireball electric in Bellflower 562-867-2317 he does everything but I'm not sure if he goes out that far.
