Lightfoot
- fort collins co
This question actually relates to a boat I am working on swapping a motor into. Its a 350 inboard with a 4bbl on it. I believe its a holley, but it has no markings that I can find at the moment. The long block that came out of the boat was rated at 245hp. The newer long block that is going in is rated at 280hp. According to the engine builder, the only difference is in the cam. I called their customer service and asked them If I would need to rejet the carb for the increase in HP, and if so, how much larger should the jets be. The answer I got was that it is usually not necessary because the cam does not have any more lift, just more duration. Im not completely satisfied with this answer, so I thought I would run it by you all on here. Im thinking that more hp means more fuel, so it has to come from somewhere. and what exactly does duration vs. lift have to do with a need for larger jets? That could be a 100% valid answer, im just hoping for an explanation.
Thanks
Lightfoot
Thanks
Lightfoot
