Re: The Colorado BS thread
started putting the new arms on today I made the mistake of leaving the jeep on the trailer and the tires as well I just put jack stands under it and and made a safety beam that hooks into the hitch and runs down to the ground just incase the stands fail it being 2x2 .250 with a large base welded to it and welded to the hitch should hold the entire rear end up no issue . I'df be done I think if I had pulld it off the trailer and removed the tires as now I have to ratchet strap the axle into place to get the bolts to line up and that is easier said than done as a 1 man operation plus climbing out from under the jeep and up and over the expanded metal covered fender makes it feel like eben longer of a job ...oh well put 5 hours in toal this weekedn should have it strtched and get started on new spring buckets next week then the bew fender hoops ,which my brainfart of cutting my 1.75 DOM .250 wall wrong now leaves me with plenty of that heavy stuff for to make fender hoops with I have about 40ft of traditional .120 ,but I figure the areas that get use constantly as rockrails will be bett of being .250 for dent resistance ... 44's should fit this new WB nicely .
