Had a blast this past weekend:
Yes, that is at Hungry Valley SVRA. the mud pit is a little deeper than it usually is :anon:
fear not though, shut the engine off as soon as i realized water was over the hood. towed it out within 10 minutes, by then the water level was almost up to my gauge cluster in the cab :laugh:
first thing we did was pull the plugs and crank out the water. no coolant came out so that was a good sign
everything was soaking (duh) so of course we pulled the distributor cap and other stuff to dry. also pulled the carpet and seats right there and started to let them dry out.
put the now dried ignition stuff back together to see if there was a chance of it starting. couldnt get spark, and i was sure there was other stuff wrong so i had it towed home
got home around 5 PM. immediately started working on it.
water got in the fuel, and the fuel pump was not working. yanked it out and jumped it with some 12v. coughed up some watery gas and then quit.
also diagnosed a bad CPS (AC volt test)
ran to Orielly and got a fuel pump, CPS, cap, rotor, some other crap
new Precision Brand fuel pump was garbage and fit like crap, returned it on sunday for a refund. tried out the original Bosch again and what do you know, it fires right up! threw a new strainer on it and slapped it back in the tank.
Then we went through and cleaned EVERY electrical connection and ground. I have a spare ECU so i swapped that in too. the old one had water coming out of it lol.
and finally, last night she came back to life:
Now that i know she runs i can go through and replace all the milkshakey fluids
oh yeah, Jeeps dont make good boats
