Been a while since another Renix XJ came into a local yard. When one does, I generally go and pick off a few spares that I can't find through the usual parts outlets.
Today was a small haul but an important one. My speedometer has been acting up for a while. If goes from not working at all (zero MPH regardless of speed), to jumping around quite a bit, to working perfectly, sometimes all on the same trip. I've had it apart several times trying to fix it (typically by adding some lube). It then works for a few days and then starts acting up again. During the Renix years, the speedo is mechanical so only a few model years will work. Mine also has cruise control so the speedo cable is in 2 parts with the CC speed sensor joining them. The last "compatible" XJ showed up like 9 months ago but someone had gotten there first and took the cluster. This time I was quick enough.
So I grabbed the cluster, the short speedo cable, the CC sensor, the center console armrest, the power mirror switch and those small trim pieces that fit over the grab handles. Once I got the cluster out, I gave the cable a quick spin by hand and the needle moved smoothly. The ODO shows 40K miles more than mine so I'll just put a small sticker under to indicate the "offset". I have no idea of the other gauges work properly but mine do so I'll swap the speedo out if I have to. Otherwise, I'm just going to swap the cluster.
