- Williams AZ
School me on this mirror thing? Why?
Nevermind...it all made sense when I git in the jeep today. :doh:
I wanted that Jeep!
But I'll get over it.
5.3 LM7
T-case shifter linkage would be another good mod. I have the Boostwerks on Scope Creep and much prefer it over the stock linkage. Much more pleasant to use. However I suspect the aftermarket linkages are less tolerant of motor/trans mount play. I am running Brown Dog motor mounts and an SFR trans mount, so that play isn't much of an issue for me, but I haven't pushed Varmint #1 in that direction on account of the potential scope creep.
Warn Hub Spin Free kit it would be perfect if you are using it for the street a lot.
I've never understood this...yes, I know what it does, just don't see the point? I've had no less than a dozen cherokees with big lifts, big tires, lockers, and none of them had poor street manors in any way. So is it just for the 0.3mpg improvement?
One that is cheap and easy with great results is a overdrive power steering pulley from PSC.
At low rpm when crawling the steering pump doesn't put out much, increasing the pump rpm helps with that by pumping more!
I'm curious to see what everyone's favorite upgrades are? Got a new 88 xj to build. Plan is 3" lift with 31s, keeping it very streetable.
Besides the obvious lift...what could you not live without doing?
Has nothing to do with MPG. XJ vibes are amplified in the cab so if you can eliminate spinning the front drive shaft you will eliminate noise in the cab. Also easy to service wheel bearings.
