marcusguy
- Jing Zhou, China
Ummm, I had an accident and dropped my pinion pretty hard. Unfortunately, the front edge of one of the teeth landed right on the metal axle and it dented it a little (the tooth). Basically it is bent a tiny bit to the coast side, not the drive side of the tooth, at the very front, by the face.
I've decided to run it and see what happens, what do you guys think? My hope that if it does fail that it won't take out the diff and maybe it will even be replaced under warranty... best case possible. Advice???
Marcus
Marcus
