Finally getting settled in at the new place, time to start working on Jeeps again. Pulled the carpet to check for rust...
Sweet, I love native SoCal cars. Only problem is when I put the carpet back now none of the back lighting on the dash works. Not a fuse or headlight switch, thinking i might have knocked a ground loose, haven't had time to check it yet. Annoying. Also, the seats had been switched around for some unknown reason, when I switched them back so the adjustment controls were on the correct sides I found out why. Something is broken in the drivers seat causing my left ass check to slide into the door while driving. Need to fix that.
Replaced the coolant temp sensor and oil pressure sending unit so now I have working gauges. The 4.0L has a pretty healthy oil leak, need to replace the OFA, rear main and oil pan gasket. Hopefully since its 2wd it won't be as big of a pain in the ass to get access.
Also picked up a brake booster and master cylinder off a '96, need to swap that out. The brakes are straight up scary on this thing, I've almost ended up in someone's trunk on several occasions.
Unfortunately I've been spending money like a drunken sailor on my new house so fixing the body panels might not happen as soon as I'd like, but there's plenty to do in the meantime including prepping my black jeep for Moab.
