WrenchedXJ
- Fuquay Varina, NC
I've been in ownership of my xj for just over a year now. Bought it with 230k miles with a bad tranny. Replaced the tranny and its gone through quite some changes since ive had it, more functionality freebie mods(fender trimming, cut and fold, etc.). A cracked freeze plug has put it out of commission. Originally, I was just going to replace the freeze plugs and be done. With now 232k original miles and unknown maintenance in the past, I'll be going a little deeper, but not major(money restricts). This is a designated trail truck that may see 2-3k miles a year. Keep a side note that within the next two years, my plans are to swap in a GM 5.3 or stroker. With no oil consumption, I have decided on a top end build only. Here is what I have planned.
Cooling
-Flow cooler High Flow Water pump
-Stant 195* Stat
-Open System radiator from newer XJ
-Taurus fans
-Freeze Plugs
Engine
-Take head to machine shop to have cleaned, pressure tested, and the valves seated.
-inspect camshaft for wear, replace as necessary.
-inspect cylinder walls for wear
-replace from head gasket up on seals/gaskets
-power steering pump
-starter
-rear main seal
Fuel system
-new fuel filter
A few things I am unsure about though. I would like to put some 4 port fuel injectors in to help, just havent decided on which ones. The other thing that needs to be replaced are motor mounts. Should I go with the OEM mounts or the daystar poly? One other thing it does every once in a while is lose oil pressure. It started to happen after I submersed my jeep in a mud hole and had a mud line at the oil filter. No valve noises when the level drops, possibly just the sending unit? Anything else I should consider?
Cooling
-Stant 195* Stat
-Taurus fans
-Freeze Plugs
Engine
-starter
-rear main seal
Fuel system
-new fuel filter
