- West Sacramento, CA
Thanks for the replies, answers are much better here than jeepforum
I Plan on regearing in july to 4.56 with a powertrax no slip in the rear. This is still my DD and i do drive around town sometimes. My lift arrived today its the 4.5 LA, i was going to raise it to 5.5 so i could have a tad bit more room to deal with. although im sure it will sit over 5.5 before it settles down.
I sort of figured run 33's with locked rear and that should do 95% of the trails around here.
swaping axles at this time is out of the picture
You can run Rubicon on 33s, one locker, and bypasses around just a couple obstacles. Fordyce Creek would be a little tough but I believe possible. Many other trails less difficult than those two will be possible on 33s. No need to go 35s.
Edit: I have run 35s on a locked D30 front, D44 rear in the Sierras, 4.88s, alloy shafts, no trusses, with no problems at all. They're fine.
