- Near Rochester NY
2000 XJ 4.0, AW4, NV242
I just took a road trip to visit a friend 900 miles away. After leavine his place, I stopped for gas. When I restarted the engine, I had a Check Gauges light and the voltmeter read zero volts. The engine was running fine, so I figured it was eroneous and I drove on. I stopped at a rest area and measured the battery voltage at 13.05V. When I restarted the car, the CG light was out and the voltage was back to normal. I drove on to 300 miles and stopped for gas. When I restarted, the oil pressure was at 0 and the voltmeter was normal. At 400 miles, I stopped and everything under the hood was normal. When I restarted the car all was well again. I stopped at 600 miles for gas. On restart, the voltmeter had dropped to zero and oil pressure was back up. I stopped again at 800 miles for dinner. Everything was fine from there home.
Any help you folks can offer is greatly appreciated.
- At no time did I loose the readings on my water temp., gas level, tach or speedo.
- Everytime I checked the battery voltage it was between 13.0 and 13.15V.
- The battery is 3 months old. All connections were cleaned and greased when the battery was installed.
- I have since cleaned and lubed all engine grounds.
