Hi Jeepers!
VEEERY SIMILAR ISSUE..
All of this concerns a
1998 GC 4.0 LTD, about 83,000 miles.
BTW I've owned this Jeep for eight yrs and, except for a regular maintenance, never had any problems with it.
Love the car..
NOW I'm really STUCK.. as it comes to the stalling issues I'm having these days.
Believe me, I have gone through various threads on this forum (and YTB) but must say I'm still not sure what the problem is.
For about a month now the Jeep has been randomly stalling on me, particularly at low RPM (stop, red light.., NEVER at full speed!),
then the RPM drops down to about 500 RPM.. and I know it's going to shut off in a few seconds.! And it IS!
And.. after a few seconds (usually) starts right back up.. like nothing has happened!! And goes and goes.. until the same happens again..
NO CHECK ENGINE or other warning light!
Tried the OBD check.. no code.
There's NO regular pattern to it.. engine cold, warm, hot.. Just happens.
So, I figured let's start with the usual culprits:
1. Took off the thottle body, cleaned it thorougly (not much carbon deposits anyway..), perfect condition..
2. Replaced all the three sensors, MAP, IAC, TPS..
3. New distributor cap + rotor
4. New spark plugs + wires
5. Cleaned/checked all relays and possible connectors, fuel pump, ASD..
6. Checked the battery terminals/ charge/ OK
Removed the ECM (PCM) computer.. just to check for any visible damage etc. Everything seems to be OK.
No loose connections, oxidations.. etc./ sprayed w contact cleaner
BTW mine doesn't come apart with just unscrewing a few TX bolts like in some previous PCMs. Totally sealed.
Have tried to wiggle the PCM connectors while the engine running.. Nope, didn't die..
After the last stall (about a week ago).. Tried to crank it over and over, spraying carb cleaner (all I had) to the intake.. and nothing.. DEAD.
One weird situation happened. At one point ALL relays started to click like crazy!! Then never again.
I had it towed to my place.
Recharged the battery over night, put in in..
AND.. the Jeep started right up, steady idle, smooth...
Every day I come by to start the Jeep up.. NO PROBLEM!! Purrs like kitten.. Steady RPM, no hick ups..
The next thing that comes to my mind is obviously the fuel pump/filter.
I can hear the fuel pump engage/prime the fuel rail.
I'm gonna check the fuel pressure asap..
As I expect, I should probably replace TPS, CMS, the coil..
and about a hundred of various components until I have found a loose ground wire, right??!!
If you are one of the Jeep (ZJ 4.0) owners experiencing the same issues, please share.
We love our Jeeps and want them keep running as long as possible..!
Thank you.
dzaby is offline
https://www.jeepforum.com/forum/newreply.php?do=newreply&p=41101487
