ZJ Wheels
MahnkenVille
Liverpool, NY
I did search, couldn't find very much on this subject...
Do ZJ 15" wheels (like these: http://syracuse.craigslist.org/pts/1414492967.html ) have the same backspacing as XJ wheels?
Also if i run these (or XJ wheels) with 3" lift and 31s, will I rub? I know i'll rub if i put them on with no lift...currently have 235s but I know i'll hit LCAs at full lock with 31s. After the lift, will i still hit? or do i need different backspacing to clear properly? If so, what BS? 4.5"? 4"?
Thanks
-Greg
31s will fit just fine on a 3" lift. you MIGHT need to do very minor trimming..
33"s will fit on a 3" lift with moderate trimming!
yep, i'm prepared for either adjusting the steering stop or just not going full lock. if i were to get new wheels, what backspacing should i get to clear the control arms?
and minor trimming is in the plans.
saw the 2nd one a long time ago, but is much more helpful now that I (sorta) know what i'm looking at when it comes to backspacing and all that stuff.
thanks, both of those will help a ton!
