ZJ 4.0 Harmonic balancer replacement
iluv83vettes
Houston
Anyone replaced the Harmonic balancer on a ZJ with a 4.0?
My father in law's is wobbling pretty bad and I would like to replace it before the rubber separates and throws the belt and needs a tow. Mainly I am wondering what all needs to be removed to get access to the pulley and swap it.
I imagine it's much like an XJ where it's easiest if you remove the front bumper and go through the crossmember. Otherwise, on a ZJ you may be able to remove the fan shroud and fan and go at it that way, but I imagine like an XJ it'd be pretty tight getting the puller in there.
