SurplusFan98
- LA
Chasing some engine shaking issues on my 98 with the 4.0. At first it was severe and I was sure it was a motor mount. Found a disintegrated one on the driver's side, and replaced it with a used but good mount. On next run, the shaking was better, but didn't go away completely. I have other XJs in the family, and this is worse than any of them, so definitely not normal. The passenger mount looks good. I don't know how to inspect the trans mount without taking all that apart, but I'll do it if I have to.
When looking around for other sources, I noticed some wobble in my harmonic balancer. I tried to wiggle it with the engine off to see if it was separated, but couldn't. I can hear a little bit of of pulley chirp after I first start the engine, but can't tell where its coming from. Goes away after about a minute. Could this be the source of the shaking that I can feel in the cab?
Other things I've checked:
- Engine idles fine at the correct RPM. If there's a misfire, I can't see it in the tach.
- Serpentine is fully tightened. Checked it with a cricket tool.
