Waterhammer
- New York, but not really
Had some front end issues recently and discovered it was an upper ball joint on the drivers side. That normally wouldn't be an issue except that I just replaced all four ball joints not 500 mi ago. I spent a decent chunk of change on moog ball joints from car quest. I did some searching here and found some people have had a similar problem with moog. When I took the front end apart I found not only the upper but BOTH lowers were bad (all had been changed at the same time). Good thing I bought all four again, rather than only buying the uppers. I got a deal on all four off of ebay, and got spicer this time. Put everything back together, greased and out for a test ride. Damn, what a difference. The spicer joints are way tighter. This was just my experience, as always, going to be different for others. I will be hard pressed to buy moog again.
