br1anstorm
- United Kingdom
My 1993 XJ 4.0 has done about 120k miles. New water pump and serp belt replaced (with an OEM Jeep/Chrysler one) at about 70k miles.
In recent months the belt has started squealing. Seems to depend on the weather (damp/humidity?) more than anything else... It squeals more or less all the time - on startup and once the engine is warm, and whether a/c is on or off. Less audible, of course, when revving up, but always there.
But here's the odd thing: if I spray water on to the belt, it instantly goes completely quiet (for about 2-3 minutes, until it dries off). So during that time I can hear - or rather not hear - any squealing noises from the a/c compressor, water pump, or any of the pulleys. All these mechanical bits seem to be running smoothly and silently. And the belt runs straight and true: no sign that the harmonic balancer is degraded or out of line. The belt itself looks fine - no fraying or signs of wear on either the flat or grooved sides.
I've checked and adjusted the tension with a Krikit (and it's on about the 150 mark). I've sanded the smooth side of the belt so it definitely isn't glazed. Still the s-o-b squeals.
What else can be causing the noise? Do I have to assume it's just some weird problem with the belt, and replace it? I just hate having to replace parts that seem perfectly good!
br1anstorm
br1anstorm
