blistovmhz
- Vancouver, BC
98xj.
* D30 front - 4.56, auto locker, WJ knuckle swap, OTK/OTA 1 tonne steering.
* D44 rear - 4.56, auto locker.
* 6.5" long arm lift
* 35x12.5R15 BFG KM2
* Toe 1/8" in.
* Caster 85.5 degrees on diff cover bolts or 4.5 on inner C's, which should be dead on for my ride height.
* Draglink and track bar angles are about 15 and 17 degrees respectively, and track bar is only about 4" shorter than the draglink.
* Camber looks about stock. I've measured but don't recall the numbers but they were identical on both sides.
* Track bar mount (frame side) is braced to opposite side frame rail.
Jeep wanders at all speeds. Feels distinctly like 1/2" toe out, but I'm definitely toed in. Steering centers quickly. I've tried setting caster all the way from 0 to 9 degrees (90 - 81 degrees at diff cover bolts), and aside from losing my centering when I'm closer to 0/90, nothing else changes. I also get a bit of bump-steer, despite the nearly identical track bar and drag link angles. When I hit something on the highway, I just get ready for the jeep to try to crash into something.
All steering components are brand new and all seem tight. Definitely no play in steering that I can feel, and steering is responsive. Tires are good (and problem exists on two different sets of tires). I may be crazy, but I'm pretty sure I didn't have this issue before installing the front and rear auto lockers.
Definitely pulls toward the downslope. Pulls hard enough that it's a chore to drive more than an hour.
Is it possible this is just how auto-lockers affect streetability, or would this indicate a twist in my axle? Perhaps something gone awry in my steering box? (I did look for a cracked frame rail but couldn't find anything).
* Toe 1/8" in.
