OMG. So after all that, I should give some back-story as to why you should never bother with RuffStuff TRE's
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I ordered the RS Chev 1 tonne steering kit. The ES2027L and ES2026R's are the high angle drag link TRE's. The also send what they call a TK234 (no differentiation between L and R) in left and right thread. Both the DL and TR ends have the same taper angle, but different depths. No problem, just ream the bigger ones deeper. Assembled and worked great, but noticed one of the TK234's had an unsealed boot, while the rest were all sealed.
Long short, all the sealed boot TRE's they sent me, failed. The one unsealed boot TK234 they sent, is fine.
They've replaced the other 3 TRE's again with the same sealed boot units, and they have all failed again, while the unsealed boot is still fine.
They replaced all the failed units, with more sealed boot units for free. When the replacement ES2026R failed again, RS wouldn't warranty and I gave up with them.
I ended up replacing their ES2026R with a Moog unit (also unsealed) and it's holding up just fine, but I still have a sealed ES2027L from RS, and it's now failing (barely noticeable, but it's definitely going) and the other sealed TK234 is also failing the same amount. Very probably is the source of all my problems.
Summation, all the sealed TRE's from RS failed repeatedly, while the unsealed unit is still fine. Strongly suspect they changed manufacturers due to the defect, but somehow they don't seem to think so, and refuse to warranty the clearly defective product. I argued that if the only unit that didn't fail, was CLEARLY a different unit (unsealed boot), then the problem was very likely their TRE's and not my setup. They disagree. I have another order open with them for some other stuff, but I'm cancelling it tomorrow, and also going to try to return the other 1 tonne TRE kit I bought from them for my buddies SAS we're building up, as I'm sure he'll have the same problem. Plus, you can get the Moog equivalents for 1/2 the price on Amazon, with 2 day free shipping.
Now the problem. No idea what the TK234 actually is. All I know is that it's got the same taper as the ES2026 and 2027's, just not quite as deep. Same rod size and pitch, same stud size and pitch.
I found the ES2010L and ES2010R have the same stud and rod size/pitch, and looks to be the same taper, but a little deeper than the TK234 (which is fine cause I can just ream out the knuckles a little farther), but as the ES2010's are a dodge application, I'm wondering if anyone knows what size vehicle these came from? I'm assuming, given the massive 7/8-18 rod, and 5/8-18 stud, that they're at least 1 tonne. Can anyone confirm?
