XJ Spindle Dimensions
ebasista
Does anyone have the inside and outside dimensions of the points on the knuckle/spindle that bolt to the ball joints. Interested in both 2wd and 4wd applications.
I'm converting the front end on my Jacobsen utility vehicle and it already has a d44 rear, and uses 5 on 4.5 bolt patterns with jeep wheels, so I figure I might as well use an XJ spindle/knuckle if the dimensions work. Right now I have about 3.5-4" of separation on my current spindle between the ball joint mounts, but really want to use a real vehicle application.
Thanks
