This will be a rebuild of some stuff on my xj. I got me a real job, moved to Michigan and a garage so its time to do some upgrades to the cherokee. Its decently "built" but I want to redo and upgrade a buch of stuff.
Heres how it sits now:
Suspension
-6.5 rusty’s coils
-Rubicon express super flex uppers/lowers (passenger side Bent)
-Rough Country Drop Brackets
-Rusty’s HD track bar and bracket converted to Ruff stuff heims on both ends
-HD Shackle Brackets
-Rough country 2 inch shackles
-s-10 bastard pack
-ss brake lines
Axles
Dana 30
-4:56s
-Lockright
-Ruff stuff cover
-Alloy tube seals
-Full circle 5-760x u-joints
-chromo shafts
-Control arm skids, boxed passenger mount
-Poison spider tie rod
8.25 29 Spline
-4:56s
-No slip
-Ruff Stuff cover
-ZJ disk brakes
-Raised shock mounts
-Superior Shafts
-u bolt style yoke
Armor
-Home made/ custom front rear bumpers rear with swing out tire carrier
-Cut out rockers for rock rails
-T-case skid
-Stock gas tank skid
Other
-Brown dog motor mounts
-AA SYE
-Spot light mount (home made)
-No carpet/ herculiner
-B&M Trans cooler with gauge
-35x12.50r15 MTR Kevelars on black steel
-Bored thottle body
It works but it needs work, last time out I bent the passenger lower control arm and now the axle is pushed back on that side and it pulls pretty bad.
Heres the plans:
Suspension:
-TNT long arm upgrade
-Possibly drop down to 5.5 inch springs
-Big off road 4 inch flex e springs
-bilstein 5150s all around
Axles:
Dana 30
-wj knuckle swap
-U bolt style yoke
-upgraded steering to go with knuckels
Armor
-jcr rear corner guards with LED light
-jcr gas tank skid
-I need to address my rear bumper also, I made it years ago but its so big it flexes and vibrates against the back.
Other:
- rear drive shaft needs balanced maybe replaced
-front drive shaft needs rebuilt maybe replaced
-more sound deading, looking into this:
http://www.secondskinaudio.com/products/Sound-Deadener-Sound-Barriers.php
Thats about it for now. Its a long expensive list so it will take some time but thats the plan. I am picking up a WJ front axle for the knuckles tommorow so the WJ swap will be first along with the long arms.
Opinions? anything you would do different? I'm trying to get it to a very capable wheeler that can still jump on the highway and cruse home.
Suspension
-6.5 rusty’s coils
-s-10 bastard pack
-ss brake lines
Axles
Dana 30
-4:56s
-Lockright
-Ruff stuff cover
-Alloy tube seals
-chromo shafts
8.25 29 Spline
-4:56s
-No slip
-Ruff Stuff cover
-ZJ disk brakes
-Superior Shafts
-u bolt style yoke
Armor
-T-case skid
Other
-AA SYE
-Bored thottle body
Heres the plans:
Suspension:
Axles:
Dana 30
-wj knuckle swap
-U bolt style yoke
Armor
-jcr gas tank skid
Other:
