NAXJA is having its 19th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
I was wondering if there was a short shifter available for a NV3500 transmission. Anybody find one? I found one for the AX-15 but i doubt this will work on the NV3500. Anybody know if one exists for the NV3500
Hurst list a number of NV3500 applications including Jeep although I think this should be NV3550. The Chevrolet S10 could be the one to go for. However, you should call them to verify first before purchasing.
I have a 2000 Jeep Cherokee Sport 5-spd. I assumed I have the NV3500 transmission but I read somewhere that the Nv3500 transmission was only made for SE models. Does anyone know definitely if I have an AX-15 or a NV3500. Just want to be looking for the right shifter...
I gotcha. I think I am going to have to go with the Jeep Wrangler Hurst shifter for the NV3550. (Verified this is what I have). My only question now is not necessary compatability of the Wrangler shifter in my XJ but moreso the placement of the shifter with respect to me in the Cherokee. I guess this is un-chartered territory since there are so few NV3550's in Xj's to begin with.
We have a B&M shifter on our Wrangler's NV3550 and it gives a much better feel for gear changes than the stock shifter. The shifter occupies the same space that the old one did and looks practically the same height too. The difference is that the fulcrum is higher so the shift travel between gears is shorter.
Out of interest, how did you verify that you have a NV3550?
Pretty much exhaustive internet searches were enough to convince me. '00 '01 Cherokee's have the NV3550...
I guess I could go with the B&M shifter then if you think that it is basically the same height as stock. I guess I would have to check out a wrangler and measure to make absolutely sure. pretty expensive to make a mistake.
Cut and weld it. I shortened my NV4500. I cut a good piece of center section out. I also tilted the shaft so it would be a better position for me to use.
