XJ magnum centering motor Q's
rockosocko
Hey Guys n Gals, Wasn't sure if this should go in the Modified section or here.
But since it won't see mud or trails and just street, I'd post here.
(btw.. Mine is a '96 2dr, 2wd that I've lowered and was driving but that dang CPS and ASD relay left me calling for a tow and burned 2 vacation days from work pissing me off enough to dive in to doing this swap)
I've been busy modding the side rails and other little piddly things getting ready to drop in a Magnum 5.2 from a Grand Cherokee and a NV3500 from a Ram 1500, and wanted to know if you guys that have done this swap, what measurements you came up with at front center at crank bolt and rear center output shaft.?
I'm coming up with 14 1/8" from either side, but that puts the header right
inline with the steering shaft, and don't want to 'ding' the new header that far. SO might have to keep to pass side an inch or so.
Any info from someone who's done it already?
Thanks
Use ZJ manifolds
