Did a big boatside pulled the junction box prior unplugging all connections and strapping harness out of the way then proceeded to cut sheet metal ,well I decided before moving on much further I should hook that back up and decide where to remount it and start it I the battery was dead for a year ..optima yellow...and I did all welding battery hooked up ...when I went start it hooked to a Good set of jumpers I got nothing , and I have no head lights park lights ect the only things that do work are the dash lights...no gauge sweep...and front turn signals no park lamps head lights ect , well the wipers also work...I did toss on my spare computer still nothing...I had no real time to trouble shoot , but figure anyone who has done a project as such has moved this box and may have had issue . it may just be I need to make sure the main harness plug that bolts to the junction box is making good clean connection it May be dirty from grinding metal dust...lol...maybe if I get enough xspower
D6500s I can winch from start to finish ?
